Multiple outputs from different Geoprocessing Tool results
408
11-23-2021 04:48 PM
HarrySmiles
I'm working on a web app that allows users to generate service profiles based on a user defined input point. It works perfectly when run, but I would like the 2nd, 3rd ... etc time it's run to produce separate results, but currently it will just overwrite each time.
Any ideas if it is possible to have it give a different result each time, hopefully based on the user input location name?
IhabHassan
Hi @HarrySmiles
ArcGIS Enterprise platform allows having geoprocessing service execution results to be shared as a service. The doco page here can give more details on this approach: https://enterprise.arcgis.com/en/server/10.8/publish-services/windows/using-result-map-service-in-we...
Regards
Ihab
