My location widget dont works
1281
09-24-2016 09:05 AM
GabrieleGARNERO1
New Contributor II
I am usig the My location widget in webapp application
When I press the viewfinder of the widget button becomes a black square often and the map is not moved in my position.
In essence, the widget does not works.
This happens both on iOS and on Android
Does anyone else have a similar Case Study?
THANK YOU
Gabriele
GabrieleGARNERO1
New Contributor II
I thank you for your precise indications,, I tried to use https, but still does not work. When I use a "blank" map, with only the basemap background, the viewfinder "My Location" works correctly, but as soon as I add any WMS service does not work anymore. Do you have any idea? If you want, I can attach the credentials of the app that I made (there are no secrets)
https://poli.maps.arcgis.com/apps/webappviewer/index.html?id=80ed408de34242e68abe307e1710f128 user: studente1
Pwd: pianificazione1 Thank you
Gabriele
