Query and Zoom to Selection (from table) not working fully
6820
10
01-28-2015 09:02 AM
PaulJordan
1> Cannot zoom to feature selected in attribute table
2> Queries pull up the relevant list of features but the created layer shows nothing.
app is here:  ArcGIS Web Application
PJ
Update:  I've been able to make this work by loading a shapefile directly to My Content and incorporating it into the map.  It will not work with data hosted on my ArcGIS server.  I'm wondering perhaps the data need to be in an enterprise geodatabase instead of file geodatabase to make this work.  I say that because Feature Access is only possible via the enterprise version.
AdrienHafner
Hi Steve,
I ended up figuring it out without having to call.  First, the Shape field is only available for display in pop-ups in Map Image Layers/Map Services, not in Feature Layers/Feature Services (not sure why).  With regard to the zoom to not showing up/being available in the Attribute Table widget, we had to make sure the layer was turned on for viewing in the Layer List widget. Our case seemed like a simple oversight on my part.  I hope yours is solved just as easily!
Adrien
