Hello, all.
I believe I need help filling some gaps in my understanding, as I thought I was following a fairly straight-forward work-flow, but after spending several hours over a few days, I am stuck.
Is it possible to download a very simple map viewer app built with the WAB from either AGOL or an on-premise Portal and deploy it to a local web server? If so, what are the steps required to allow it to run using only on-premise Portal resources?
We want to deploy a very simple map viewer app built with a publicly accessible map service to our local web server. I have tried building the app in the WAB in AGOL and I have tried it with our on-premise Portal, but I cannot get the app to work after it is downloaded. Our Portal and ArcGIS server are on the same server. The ArcGIS server has not been federated with the Portal. We are using Portal-tier authentication. The web map and the layer are publicly shared.
I have followed this workflow before in earlier versions of Portal, but used a downloaded version of the DEV WAB. Do I need to download the WAB and use it to create an app?
I have been able to download a viewer app that continues to use AGOL, but would like to remove the reliance on AGOL services and maps.
Thanks for reading and thanks in advance for any help/pointers.
