Share Widget Not working?
3959
9
06-16-2016 08:34 AM
AnaHiraldo
New Contributor II
Help!
I was really excited to see a shared widget added to the WebApp Builder, but it is not working for me.  I follow the instructions on "How to use this widget" and was hoping I was doing something wrong.  When I add the icon and launch; click on the icon and a blank dialog window appears.   None of the options as described here ​show up.
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Ana,
The Share widget is working for me. Is there anything special with the web map you're using?
AnaHiraldo
New Contributor II
Not really
App is build using published services mostly from one source and they are all public.
Sent from my iPhone
BillSpiking__GISP
Hi Derek,
I'm getting the blank window as well.  I've tested with the following browsers:
Chrome 51.0.2704.84 m
IE 11.0.9600.18163
Firefox 28
Thank you,
Bill
LemaoWu
Hi Ana / William,
Could you find any errors in your browser console?
BillSpiking__GISP
See image below.  I'm using the launch pad theme.  Message me if you need the entire console log.
Thanks!
AnaHiraldo
New Contributor II
No errors.
LemaoWu
Thank you @William and @Ana! We found the problem: it happens if you're a user with custom role. Will let you know once we patching it.
LemaoWu
@William and @Ana could you check it again? The fix has been made.
BillSpiking__GISP
Works like a charm!  Thank you Lemao Wu​!
