summarize by polygon in ArcGIS Online webapp
4717
14
05-02-2017 07:06 AM
deleted-user-3QvhwBivZdaR
I would like to add a widget to my Web App Builder based AGOL app, which can return a summary of points within a polygon from another layer.  Can this be done?
I dont want anything that has prebuilt summaries.  The Info Summary tool looks close, but it looks like it only return the sum of the features within the current map extent.  Is there a away to use this so I can get a summary within the bounds of a polygon feature? So far I haven't had any luck figuring this out.
Thanks, Jason
DerekLaw
Esri Esteemed Contributor
Hi Jason,
Please checkout the Analysis widget, it has a tool called Aggregate points which may meet your needs.
More on the spatial analysis capabilities of the Analysis widget,
Perform analysis—ArcGIS Online Help | ArcGIS
Hope this helps,
thanks, I did look at that a bit, was hoping for something that would not consume credits. I will look at those tools again.
AmitKokje3
Not sure if this question is answered in other discussions,. but did summary widget clusters polygons and lines as well?
I configured the widget for a project layer with polygon features. The summary dashboard works well with all the necessary info as required. But no clustering is visible for different project area polygons.
Does the widget works only on point features?
Thanks.
DerekLaw
Hi Amit,
The Summary widget will summarize points, lines and polygons, but only point features can be displayed as clusters. Clustering lines and polygons wouldn’t make sense in most cases, because they could represent large irregular geometries that cannot necessarily be represented by points.
Hope this helps,
AmitKokje3
Thanks Derek,
I think ESRI should consider the clustering option for lines and polygons  as well. ESRI partner Apps  such as GeoCortex (Latitude Geographics) enables clustering the two geometries through the GeoCortex apps. It is quite useful and in demand. Especially  when displaying the multitude of project areas, transport activities across the town as an overview. The current workaround workflow to display the clustering for polygon features is generate centroids and use it for clustering. Which is bit unnecessary.
Many business units prefers and demands to visualize the multiple project areas (polygons) spread across the city as overview clusters through a web app.
GeoCortex App native clustering for Polygons: This application overviews many transport project areas across the city as cluster.
DerekLaw
Hi Amit,
Thanks for your feedback. Please post your enhancement request on the ArcGIS Ideas site so we can gauge interest from the Web AppBuilder user community as well.
Hope this helps,
AurelieShapiro
Occasional Contributor II
So is there no way to summarize points within a selected polygon in Web App Building without consuming credits?
Seems like a simple task (if you had the patience you could draw a polygon in the map and get a summary). But it would be great if someone could use the select tool to choose, say a country, and then use another tool to summarize points in that layer? Seems so simple that it's not worth spending the credits...we spend enough on storage and accounts I'd rather not give more on credits for easy analysis (especially since you can't trace those credits back to a specific user in our group, so someone needs to suck up the costs - very risky). I guess I will have to spend the time to program it myself in model builder?
DerekLaw
Hi Aurelie,
Actually, you can. An admin can login to the ArcGIS Online organization > Organization page > View Status > Credits tab.
You can click on an analytics column in the histogram, which should display the "Usage Aggregation by Type"  donut chart underneath the histogram. When you select one of the analytics usages - you will see which member consumed those credits.
Hope this helps,
AurelieShapiro
Yes but the credits are not attributed to a specific user if we have a public facing app? I.e. who to allocate the limit to?
Aurélie Shapiro
Remote Sensing Specialist
WWF Germany
aurelie.shapiro@wwf.de
www.wwf.de/remote-sensing
