Survey123 connector to Power Automate causes error when survey includes repeat function
967
02-24-2022 06:12 AM
BenediktBreitschopf
Hi community,
we are trying to extract the attachment images from a survey with a repeat function and use Power Automate for it in order to store them in SharePoint. The process flow works fine for simple surveys without the repeat function, but for surveys with this function it shows the following error message when trying to save the flow: The response from API 'survey123' operation 'GetWebhookPayloadSchema' with status code '200' does not contain a valid OpenAPI schema object.
Images for further details are attached.
Does anyone know how to solve this?
LucasMNDNR
Were you successful in finding a solution?
CindyThibeault
Did you find a solution? @LucasMNDNR  I have the same issue
CindyThibeault
Yes @BenediktBreitschopf were right, you have to  cut the repeat for it to work!!
TL2
Occasional Contributor III
I had this issue and fixed it by adding labels to all my repeats which were previously blank,
