Dear Readers,
thank you for taking the time to read this posting: I had downloaded WAB 1.3. after successfully adding a SQL Spatial point layer to ArcMap, I had published map and feature services from the same map document.
To use it WAB, I had created a new Web Map and consumed the feature service.
After creating a new website with edit widget, the editor was able to change the attributes of the point feature but could not move - I went back and checked to see whether the 'disable geometry change' check box was checked = true by mistake. Not it was not checked = true.
So attribute changes were recorded and were verified from another machine. I am not able to move the point to a new location,
any help or suggestion would be greatly appreciated.
regards
ravi.
