WAB 1.3 edit widget not moving points - Attrib edit OK.
2579
02-03-2016 03:25 PM
Ravichandran_M_Kaushika
Dear Readers,
thank you for taking the time to read this posting:  I had downloaded WAB 1.3.  after successfully adding a SQL Spatial point layer to ArcMap, I had published map and feature services from the same map document.
To use it WAB, I had created a new Web Map and consumed the feature service.
After creating a new website with edit widget, the editor was able to change the attributes of the point feature but could not move - I went back and checked to see whether the 'disable geometry change' check box was checked = true by mistake. Not it was not checked = true.
So attribute changes were recorded and were verified from another machine.  I am not able to move the point to a new location,
any help or suggestion would be greatly appreciated.
regards
ravi.
JordanBaumgardner
Occasional Contributor III
I would watch the update traffic with the F12 tools. The response probably has a message for you.
TrentReeder
Is your feature service based on feature class that is part of a geometric network?  There is a limitation for editing geometric features in a feature service because of the coordinate systems not being the same.  That has been an issue for us in the past.
JordanBaumgardner
Jordan and Trent,
good afternoon. sorry for the delay in responding to you.  I created a new service and it fixed it.
I am unable to mark both of your responses as correct answer.
regards
ravi.
