WAB: Change Layer List 'Description' option
3071
6
10-27-2015 02:43 PM
MatissValdmanis1
Hello everyone,
I am using Web AppBuilder Developers Edition and want to change the Layer List "Description" option. When you run an app, when you click on the drop down beside a layer in the Layer List you are given the option to view the layer's 'Description'. This automatically opens the layer's REST endpoint URL.
I am wondering if there is a way to change the 'Description' option to show a custom URL website I can create myself, or even just the layer's "Description" value - you can edit this in an mxd by opening the layer's properties, under the General Tab, and then republishing the mxd to a Map Service that AGOL (and thus WAB) uses.
MatissValdmanis1
Hi Robert,
Unfortunately
url = ((this._layerInfo.layerObject.name) + '.com');
returned undefined again,
However I've got a solution that works now:
} else if (this._layerInfo.layerObject && this._layerInfo.layerObject.url) {
        //url = this._layerInfo.layerObject.url;
       url = ((this._layerInfo.id) + '.html'); //MV added
        label = this.nls.itemDesc;
That code returns .../webappbuilder/apps/3/(Mapservice_Name)_3308_3.html
I can build the description/metadata websites off of this.
Thank you so much for the help!
RobertScheitlin__GISP
Matiss,
   Sure you can have that option in the menu do what ever you want just open the:
[install dir]\server\apps\[app #]\widgets\LayerList\PopupMenuInfo.js
and find the _getATagLabel function this is the function that set the anchor hyper link to the layers rest end point page.
MatissValdmanis1
Thank you Robert! Definitely got me closer. However, I am not sure how to change which URL it goes do (please bear with me, I am still new to WAB JS).
As it stands I can't seem to get the layer's name string value - I could make a small html Description/metadata website for each layer if I could just get the layer's name value and pop the websites in the ...apps/[app #]/ folder.
Here is the code I have put in the _getATagLabel function:
_getATagLabel: function() {
      var url;
      var label;
      var itemLayerId = this._layerInfo._isItemLayer && this._layerInfo._isItemLayer();
      /*if (itemLayerId) {
        url = portalUrlUtils.getItemDetailsPageUrl(
                portalUrlUtils.getStandardPortalUrl(this.layerListWidget.appConfig.portalUrl),
                itemLayerId);
        label = this.nls.itemShowItemDetails;
        this._layerInfo.layerObject.url &&
        (this._layerType === "CSVLayer" || this._layerType === "KMLLayer")) {
        label = this.nls.itemDownload;
      } else {
        url = '';
      } */ MV removed
   url = ((this._layerInfo.layerObject.layerId) + '.com'); //MV added - returns 'undefined.com'
      label = this.nls.itemDesc; //MV added
      return '<a class="menu-item-description" target="_blank" href="' +
        url + '">' + label + '</a>';
Matiss,
  If you are just wanting the layers name then just use "name" there is no property called "layerId" in the layerObject.
url = ((this._layerInfo.layerObject.name) + '.com'); //MV added - returns 'layername.com'
MatissValdmanis1
Hi Robert,
Unfortunately
MatissValdmanis1
Also
       url = ((this._layerInfo.title) + '.html'); //MV added
Works, returns
.../webappbuilder/apps/3/(layer name).html
​However spaces in the layer name make it unusable
Matiss,
   Glad you have it working. Be sure to mark this thread as answered.
