WAB change symbology
4703
01-18-2016 06:38 AM
OndrejFialík
New Contributor II
Hello,
how can I dynamically change the symbology on layers? I need to temporarily change the symbology for the selected layer.
Thanks
Ondra
GirishYadav
Ondrej,
If the layer is GraphicsLayer or FeatureLayer then simply use .setRenderer(renderer) method to change the renderer.
FeatureLayer | API Reference | ArcGIS API for JavaScript
And if its ArcGISDynamicServiceMapLayer then you need to use .setLayerDrawingOptions() method.
ArcGISDynamicMapServiceLayer | API Reference | ArcGIS API for JavaScript
-Girish
MichaelRobb
Occasional Contributor III
It would be nice to have a more detailed post of what you are asking, but I will attempt to guess...
If you are referring to changing the symbology on a publishing level (not a user having the ability to change the symoboloy)
Symbology can be changed on the Web Map level.
Left click on the layer in the web Map >> Change Style
Ref:
Change style—ArcGIS Online Help | ArcGIS
OndrejFialík
New Contributor II
I need change style in WebAppBuilder application. Seeking a way the user can edit the layer style via widget.
I use jimu/dijit/SymbolChooser for create SimpleRenderer bud i dont know how change layer style.
GirishYadav
Ondrej,
-Girish
OndrejFialík
New Contributor II
Hi Girish,
thanks!!!
LayerDrawingOptions is what I was looking for.
Ondra
KisakyeM
New Contributor III
@OndrejFialík did you ever get this to work? Do you mind sharing the code that you used?
