Is there a way to restrict the feature action options in WebApp builder?
WebApp Builder 2.3 enables widgets to cross-interact with each other using feature actions. For example - the default pop-up can be used to set a feature as input to geoprocessing widgets; the "SELECT" widget also gives the option to use selection as input to geoprocessing tools.
I have three geoprocessing widgets in my application and they all appear as feature action options in the pop-up and SELECT widget options. I want to ideally be able to either disable any geoprocessing tool of choice or disable all of them.
I tried deleting the feature action setting in the app config.json but no success. I have also taken a look at the FeatureActionManager.js and BaseFeatureAction.js file (located in the jimu.js folder) but no luck.
Any suggestions/pointer will be appreciated.
Thanks
Offie
