WebApp Builder for ArcGIS username and password issue
3908
04-14-2016 09:15 AM
HabG_
Hi All
I have created a secure service (Using GIS Server Authentication Tier) on ArcGIS Server and published it as a web map in ArcGIS Online. I have created a web mapping application in WAB and when I launched the app from WAB the Sign In page displays and I am able to sign in using the username and password I have created in my ArcGIS Server Manager Configuration Settings. However, when I downloaded the app and copied it to the wwwroot directory and browse for the app, I cannot sign in using the same username and password.
Is there any configuration I need to apply in order to sign in using the same credentials?
TobiasFimpel1
Regarding your screenshots: One of the prompts asks you to authenticate to ArcGIS Online (in order to access the item). Use your ArcGIS Online username and password there, or else share the item (likely the webmap) publicly . The other one asks you to authenticate to your ArcGIS Server site, use your ArcGIS Server credentials there. If this is already what you are doing then disregard, just wanted to make sure you know this. -Tobias
ronaldmcfarlane
Have you tried preceding your login name with the domain name?  e.g., "myCompany\myuser".  That is what I have to do with my system.
TobiasFimpel1
HabG_
Thanks Tobias,
As you said it, my webmap was not shared publicly. Now I have shared it publicly and it is accepting the username and password. Thanks again.
Hab
