Cannot modify log level in Workflow Manager Advanced Settings
783
07-31-2019 08:14 AM
Ulises
I'm trying to modify the log level in the WMX Advanced Settings but I received the following message...
"Application attempted to perform as operation not allowed by the security policy..."
"Requested registry access is not allowed."
User is local administrator and have required permissions in the corresponding directories.
Any help is appreciated.
Ulises Feliciano Troche
Ulises
Thought I share this...
To overcome the error message above, it was just a matter of opening the tool selecting the OS option to "Run as Administrator".  For some reason it doesn't matter the user is in the administrator group, you have to choose this option to be able to be able to change anything without errors.
On the other hand, we found that no matter the log level defined we were not able to see any log files when using ArcGIS Pro.  Looks like the log files are created just when using the WMX stand alone application.
