Job Notifications and Related Properties
1181
05-03-2012 03:38 PM
FraserHand
Occasional Contributor III
Hi There,
Has any seen this? I have a job notification set up to report on a related field (1:m) - but nothing shows in the subsequent email. I thought it may display the last row of the table?
Anyone?
P.S. I'm not getting a load of love from this forum 😄
TopeBello
The WMX tokens do not work with the linked properties, [JOBEX:...] only applies to the extended properties values. This is a limitation at the current version and should be addressed in a future release. The resolution is to add the records as a comma delimited list of values at run time.
Tope
FraserHand
Thanks Tope,
Have you got a sample or code snippet of implementing this?
Cheers,
Fraser
TopeBello
Hi Fraser,
What I meant by the resolution below was describing the way we solved this. We have added this fix to 10 SP5 and 10.1. 10 SP5 will be available for download within the next few weeks.
I hope this helps.
Tope
