Unexpected behavior in TAM: Hide Toolbar(s) command
624
01-23-2012 06:29 AM
AshleyMott
I use the "Hide Toolbar(s)" command from the "Task Manager Utilities" in a Task Assistant Manager workflow in order to limit the user experience in ArcMap. I set up the "Command Parameters" to hide all toolbars with the exception of just a few. This command works if some of the toolbars already exist in the user's ArcMap. However, when a user enacts the command and those toolbars do not exist in the user's ArcMap the toolbars that should be hidden then all pop up in ArcMap (not docked).
Is there an issue with this command?
AshleyMott
Bug: NIM07783
