WMX 10.1 - AOI Graphic Polygon in Job Map document
1666
07-18-2013 12:15 PM
DahaeHwang
At WMX 10.1, the AOI appears as a polygon graphic (slashed red lines) in a job's map document. Is this a new change at 10.1? Is there a way to change this symbol or disable it? At previous versions (~10), it only appreared in the JTX_JOBS_AOI layer.
Any help would be greatly appreciated!
by Anonymous User
Not applicable
Hi Dahae,
That???s right the AOI should now appear as a graphic in the map, and it should show in the TOC as a graphic that you can turn on and off. In the advanced options of Launch ArcMap there is a 'Show AOI in MXD' that you can check on or off to suppress the graphic if you do not want to see it.
Cheers,
Michael
DahaeHwang
Found that this is a new feature @ 10.1- the polygon was in the graphic layer that WMX automatically added to the map.
by Anonymous User
Not applicable
Hi Dahae,
Cheers,
Michael
