Workflow Manager Samples Integrated with Ops Dashboard Now Available on Github!
3664
03-22-2016 04:26 PM
by Anonymous User
Not applicable
Learn how to unlock the power of Workflow Manager within JavaScript applications. These samples show how to integrate Workflow Manager functionality within existing applications, such as the Operations Dashboard.
https://github.com/Esri/workflowmanager-dashboard-samples
AjitkumarBabar
Occasional Contributor II
Nice development.
I have a question, is it possible to run launch ArcMap step to initiate editing from Javascript Workflow Manager viewer?
by Anonymous User
Not applicable
Hi Ajitkumar,
You can't use Launch Arcmap on the web to initiate editing session from the JavaScript web viewer. Any step type that is listed under the JTXDesktopSteps node in the Workflow Manager Administrator is for Desktop use only.
If you wanted to open an editing web viewer you could do so through the LaunchURL step execution type. You would need to configure an editing viewer with your mapping data and then Workflow Manager could open it when you execute the step.
Cheers,
Michael
