Hi all,
I am trying to overwrite the assignment with a layer that kind of follows these guidelines: Workforce schema—Workforce for ArcGIS | ArcGIS. I can see the assignments just fine when I open the workforce project but when I try to add workers I get "Item is not accessible" in dev mode of my browser.
Here are the fields I have in my layer:
So I have the fields I need to supply:
You need to supply values for the following fields:
Field | Definition | Value to provide |
SHAPE | The point location of the assignment | An x,y coordinate pair |
status | The assignment's status, from the values in the Assign_Status domain | - 0 (Unassigned) to create unassigned work
- 1 (Assigned) if you are going to assign the work as part of its creation
Caution:If you are going to assign the work, you also need to include values for the workerId and assignedDatefields, described in a later table. |
assignmentType | The type of the assignment, from the values in the Assign_Type domain | Any valid value from the Assign_Type domain |
location | Text description of the point location of the assignment | An address; an x,y coordinate pair; or any descriptive text |
assignmentRead | Specifies if the worker has viewed the assignment | 0 since the assignment is unread |
dispatcherId | The ID of the dispatcher creating the assignment (dispatchers.OBJECTID from the Dispatchers layer) | May be the dispatcher ID for the ArcGIS organizational user you are connected as, or could be the ID of a particular dispatcher associated with the project |
Questions:
1. Should I remove all the extra fields and keep only what is needed for workforce?
2. Is the process of overwriting the assignment layer breaking something in the app itself?
Thank you,
Alex
