So I set up Workforce to link to a Collector map, the ID field auto populates into the appropriate field in Collector, layer. I can edit the fields, but when I try to add geometry (polygon) the red dot just moves, it does not allow me to create the poly. When I don't use the auto populate field and open the layer directly, the geometry add works. Any thoughts...
