No, I am trying to populate the Work Order ID box by manually adding the Work Order ID into the text of the link, like the documentation indicates you should be able to do.
Eventually, the plan is to have this built into a model, but at the time being I can't get a stand alone link to populate that field, and I am not sure why, when other fields are populating fine.
The end use case is making it easier to create new assignments from a selection of features on ArcPro, because most of the information to populate the assignment already exists or there is a default value for most of the fields. I have tried a different approach of appending selected features to the workforce layer with the correct fields, but was running into different issues with that method as well.
