Adding XY event source programatically
928
8
04-03-2013 09:17 AM
MikeDuppong
I can add a table as an XYEventSource from an Access database, with the following code.  This works.  My problem is described after the code block.
srWorkspace = ao.OpenAccessWorkspace(dataSource);
srTable = ao.OpenTable(srWorkspace, "MyTable");
IDataset dataSet = srTable as IDataset;
IName tableName = dataSet.FullName;
IXYEvent2FieldsProperties xyEvent2FieldsProperties = new XYEvent2FieldsPropertiesClass();
xyEvent2FieldsProperties.XFieldName = "myX";
xyEvent2FieldsProperties.YFieldName = "myY";
IXYEventSourceName xyEventSourceName = new XYEventSourceNameClass();
xyEventSourceName.EventProperties = xyEvent2FieldsProperties;
xyEventSourceName.EventTableName = tableName;
ftrLayer = new ESRI.ArcGIS.Carto.FeatureLayerClass();
SpatialReferenceEnvironment spatRefEnv = new ESRI.ArcGIS.Geometry.SpatialReferenceEnvironmentClass();
IGeographicCoordinateSystem geoCS = spatRefEnv.CreateGeographicCoordinateSystem((int)ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984);
geoCS.SetFalseOriginAndUnits(-180, -90, 1000000);
xyEventSourceName.SpatialReference = geoCS as ESRI.ArcGIS.Geometry.ISpatialReference;
IName xyName = xyEventSourceName as IName;
IXYEventSource xyEventSource = xyName.Open() as IXYEventSource;
IStandaloneTableCollection pTableCollection = map as IStandaloneTableCollection;
IStandaloneTable standaloneTable = new StandaloneTableClass();
standaloneTable.Table = srTable;
pTableCollection.AddStandaloneTable(standaloneTable);
ftrLayer.FeatureClass = xyEventSource as IFeatureClass;
ftrLayer.Name = "My Table";
map.AddLayer(ftrLayer);
The problem I'm having is that it's adding the table to the map as a feature layer with a feature class, and I don't want that.  I want it to behave exactly as if the user right-clicked on the table in ArcMap and chose the "Display XY Data..." menu item.
Right-clicking on the layer created as above and choosing Properties shows this for the source:
Data Type: XY Event Source
Feature Class: MyTable_Features
Feature Type: Simple
Geometry Type: Point
However, if you conduct the Display XY Data operation manually in ArcMap on a standalone table added to the TOC, the following shows for the source, and this is what I'm after:
Table: C:\data\database.mdb\MyTable
X Field: myX
Y Field: myY
Has Object-ID Field: Yes
What in the world am I doing wrong?
Thank you for any assistance!
Mike
LeoDonahue
Occasional Contributor III
map.AddLayer(xyEventSource);
Wouldn't this work?  XYEventSource implements ITable, which you can pass to your map.AddLayer() method.
MikeDuppong
Negative.  AddLayer() requires an ILayer.
LeoDonahue
doh.  sorry about that...
I meant map.addTable()
MikeDuppong
Thanks for the response.  However, I don't see an AddTable() method for the IMap interface.
LeoDonahue
IMap is an Interface for concrete classes: Globe, Map, Scene.
IMap would not have an addTable() method because Globe and Scene would need to implement that contract.
How did you create your IMap variable?
MikeDuppong
IMxDocument pMxDoc = m_app.Document as IMxDocument;
IMap map = pMxDoc.FocusMap;
m_app is set within the OnCreate() method of the BaseCommand:
if((hook) is IMxApplication)
  m_app = (IApplication)hook;
LeoDonahue
pMxDoc.FocusMap
This returns an IMap reference.
You need to QI (or cast) to the Map class if you want to use addTable().
MikeDuppong
pMxDoc.FocusMap
Thanks for sticking with me, Lee.
I QI'd the IMap to an ITableCollection and used its AddTable() method.  This results in:
Data Type: Standalone Table
Table Name: MyTable_Features
Table Type: XY Event Source
Still not quite there.  Still shooting for:
X Field: myX
Y Field: myY
I feel like I'm painfully close...
