Autoload AddIn Extension in ArcCatalog
2585
08-25-2010 05:21 AM
DaveMcPherson
New Contributor III
I have recently upgraded to ArcGIS10 & am using VS2010 with VB.Net and ArcObjects.
I'm trying to port my VBA customisations across to the VB.Net environment. I have a simple utility which unloads any loaded extensions (3D, Spatial, Network & Publisher) on shutdown of both ArcMap & ArcCatalog, so that at next startup they are switched off.
I have successfully ported the ArcMap version, creating an add-in extension which autoloads & hooks into the IDocumentEvents.CloseDocument event to fire the script. However, I cannot get ArcCatalog to autoload any extension created as a Desktop AddIn Extension - i.e. not associated with any UI controls. The extension startup event stubs fail to fire, indicating that no autoload is taking place despite this being specified in the wizard & addin config XML - autoload = "true". For pure code-based extensions, there does not seem to be any other way of enabling them via the AddIn Manager, other than by auto-loading them.
I would like to avoid having to go the route of developing a fully managed extension for this simple task, which should be achievable using the Desktop AddIns.
Any ideas?
Dave
georgandersson
hi dave
did you solve this issue?
regards
george
DaveMcPherson
New Contributor III
Hi George
Yes, after upgrading to the ArcGIS10 SP1 release I had no more problems with this.
Regards
Dave
