I develop on C# .NET 3.5 with ArcGis10.
I created a desktop baseToolBar / base Command DLL and registered it with the esriRegasm.exe" command."
My baseToolBar Dll ,has references to other dll's,and use their methods(as common.dll ,etc.)
Now, after I made changes in the TB , unregister and again register it, it doesn't recognize the changes in the Internal dll.
For example, if I change the header of method with one parameter 'Func1(p1)' to method with two parameters 'Func1(p1,p2)' , when calling from the main dll to 'Func1(p1,p2)' it throws an error that Func1 has invalid number of argument.
It seems that the previous version of that dll , was not updated on the registration.
I found a temporary solution and not comfortable and not useable , that when I remove the NORMAL.mxt of the ArcGis desktop , most of the times the problem is solved, but sure it can't be my permanent solution.
This problem started when we upgraded from ArcGis 9.3.1 to ArcGis 10.
Thank's.
