Hello experts,
when trying to sign my ArcMap-Addin with the ESRISingAddIn.exe-Tool I receive the following message
--------------------------- Esri Digital Sign Add-In Utility --------------------------- MS.Internal.IO.Packaging.CustomSignedXml.GetNetFxSecurityRegistryValue(System.String, Int64) --------------------------- OK --------------------------- |
followed by
--------------------------- Esri Digital Sign Add-In Utility --------------------------- Failed to sign the add-in. --------------------------- OK --------------------------- |
Do you have any idea what could be the source of this problem.
Everything went fine with version 10.1 before, after upgrading to version 10.2.2 this error occurred.
The machine had ArcMap 10.1 and ArcObjects SDK before, both where updated to version 10.2.2.
OS is Windows 7 SP1 x64.
Any hint will be appreciated.
Thanks in advanceFossi
