Dear,
I have a shp file, whose attribute table contains duplicate rows with the same GID1 (esritypedouble).
Among the duplicate rows, their status could be R, S, W, O.
I wanna merge the status into one string field.
For instance,
GID1
434 R S W => R, S, W
I found the relevant code below but could not implement in my shoes.
(typemismatch in
Const LOCATIONID_FIELD As Double = "GID1")
Please kindly help and thanks. (the attached shp for use)
code
Public Sub ConcatenateField()
' Removes duplicate records (based on LocationID field)
' Concatenating the Business field.
' ---- Modify these values as appropriate ----
Const BUSINESS_FIELD As String = "C0440"
Dim pMxDoc As IMxDocument
Dim pSATblColl As IStandaloneTableCollection
Dim pTbl As ITable
Dim pCsr As ICursor
Dim pRow As IRow
Dim pNxtRow As IRow
Dim sLocID As String
Dim sNxtLocID As String
Dim sBus As String
Dim sNxtBus As String
Dim lLocIdx As Long
Dim lBusIdx As Long
Dim sConcat As String
Dim pTblSort As ITableSort
Dim pEditor As IEditor
Dim pID As New UID
' Make sure we're in an edit session
pID.Value = "esriEditor.Editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
If pEditor.EditState = esriStateNotEditing Then
MsgBox "Please Start An Edit Session On The Table"
Exit Sub
End If
' Get a ref to the first table in the map
Set pMxDoc = ThisDocument
Set pSATblColl = pMxDoc.FocusMap
Set pTbl = pSATblColl.StandaloneTable(0)
' Get the field indexes
lLocIdx = pTbl.FindField(LOCATIONID_FIELD)
lBusIdx = pTbl.FindField(BUSINESS_FIELD)
' Get a sorted cursor on the table
Set pTblSort = New TableSort
With pTblSort
Set .Table = pTbl
.Fields = LOCATIONID_FIELD + "," + BUSINESS_FIELD
.Ascending(LOCATIONID_FIELD) = True
.Ascending(BUSINESS_FIELD) = True
.Sort Nothing
End With
' Start an edit operation (so that it can be undone)
pEditor.StartOperation
' Loop thru all the sorted records
Set pCsr = pTblSort.Rows
Set pRow = pCsr.NextRow
sLocID = CStr(pRow.Value(lLocIdx))
sBus = "," + pRow.Value(lBusIdx) + ","
Set pNxtRow = pCsr.NextRow
While Not pNxtRow Is Nothing
sNxtLocID = CStr(pNxtRow.Value(lLocIdx))
If sNxtLocID = sLocID Then
' Concatenate the Business field for duplicate records
' and delete the duplicates.
' Only concatenate unique Business field entries
sNxtBus = pNxtRow.Value(lBusIdx)
If InStr(sBus, "," + sNxtBus + ",") = 0 Then
sBus = sBus + sNxtBus + ","
End If
pNxtRow.Delete
Else
'Store the record with the concatenated Business field
sBus = Mid(sBus, 2, Len(sBus) - 2)
sBus = Replace(sBus, ",", ", ")
pRow.Value(lBusIdx) = sBus
pRow.Store
Set pRow = pNxtRow
End If
' Get the next record
Wend
' Store the last record
pRow.Store
' Stop the edit operation
pEditor.StopOperation "Concatenate Field"
' Inform the user we've finished
MsgBox "Concatenation completed", vbInformation, ""
End Sub
