Solved! Go to Solution.
we use our own COM categories in our extension
I don�??t have specifics on when the instructions will be released or what form it will be in, but it will probably be a blog or a KB doc.
We will provide documentation that will describe how customers can register their legacy components with ArcGIS 10. Like you said, ESRI will not provide support for this workflow, so if it doesn�??t work you will not be able to call Technical Support. There will be no guarantees that this registration process will work, and no guarantees that the component will work in the new version.
