Error Running LicenseInitializer
4574
06-17-2010 07:31 PM
SethPatrich
I am running a console app in Visual Studio 2010 that uses the LicenseInitializer code. I get the following error when I try to run the app:
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred in TestApp.exe
Additional information: Retrieving the COM class factory for component with CLSID {E01BE902-CC85-4B13-A828-02E789E0DDA9} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
It breaks on this line of code:
        private IAoInitialize m_AoInit = new AoInitializeClass();
Any ideas?  Am I not correctly registering the ESRI dll's?
Seth
FrankHochstrate
No replies until now.
Do you have a solution by now?
I've got the same or a similar problem, but only on a windows 7 system.
Any helpful ideas are welcome.
Regards,
Frank
BramVan_Helleputte1
As ArcGIS is a 32bit application you have to change the target platform to x86 for the project that checks out the license;
Go to project properties > build > platform target > change anyCPU or whatever this says to x86
