I am developping 3 toolbars with multiple buttons and decided to have my buttons in different namespaces. I looked up the <AddIn>'s namespace parameter and the <Button>'s class documentation , before changing anything.
The <Button>'s class documentation states :
"If this class is not in the default library namespace specified on the root AddIn element, the class name must be the full name (namespace.className)"
However, if i enter any values with ".", the ArcGISAddInHostGenerator generates invalid Config.Designer.cs entries...
For exemple :
internal class IDs {
/// <summary>
/// Returns 'TestNamespace_cmdTest', the id declared for Add-in Button class 'TestNamespace.cmdTest'
/// </summary>
internal static string TestNamespace.cmdTest {
get {
return "TestNamespace_cmdTest";
This yields the two following errors :
Error 1 The modifier 'static' is not valid for this item
Error 2 The modifier 'internal' is not valid for this item
Of course, i could go back to "everything in the same namespace" but id rather not, especially if this is documented as a supported feature...
Anything im doing wrong or is this a bug/wasn't tested ?
Thanks in advance
Edit, for reference, this would be the button entry in the Config.esriaddinx
<Button id="TestNamespace_cmdTest"
class="TestNamespace.cmdTest"
message="Test"
caption="Test"
tip="Test"
category="Test"
image="Images\Test-64x64.png"
onDemand="false"/>
