Find polygon centroid in C# or vb.net
7061
09-07-2012 10:36 AM
JoseSanchez
Hi all,
I am looking for asamples that shwo how to find a polygon centroid in C# or vb.net
thanks
RichardFairhurst
MVP Honored Contributor
Hi all,
thanks
You need to access the Centroid through the IArea interface.  There is an example that extracts the Centroid's X and Y coordinates and that creates a Centroid point object from the shape input's area interface here.
KevinOrcutt
This might be overkill, but here is a quick snapshot with slight modifications of some code that I use to get a centroid of a polygon feature...
    Private Function GetPolygonFeatureCentroid(ByVal PolygonFeatureLayer As IFeatureLayer) as IPoint
        Dim PolygonFeatureClass As IFeatureClass
        PolygonFeatureClass = PolygonFeatureLayer.FeatureClass
        Dim PolygonFeatureSelection As IFeatureSelection = PolygonFeatureLayer
        Dim PolygonFeatureSelectionSet As ISelectionSet = PolygonFeatureSelection.SelectionSet
        Dim PolygonFeatureCursor As IFeatureCursor
        Dim newPolygonFeature As IFeature
        Dim newPolygonArea As IArea
        Dim newPolygonFeatureCentroid As IPoint
        Dim queryFilter As IQueryFilter = New QueryFilterClass()
        'ToDo: Setup the where clause here to select the feature that you want...  or skip altogether if you already have that feature!
        PolygonFeatureFSelectionSet = PolygonFeatureClass.Select(queryFilter, esriSelectionType.esriSelectionTypeSnapshot, esriSelectionOption.esriSelectionOptionNormal, Nothing)
        PolygonFeatureCursor = PolygonFeatureClass.Search(queryFilter, False)
        If PolygonFeatureFSelectionSet.Count > 0 Then
            newPolygonFeature = PolygonFeatureFCursor.NextFeature
            newPolygonArea = newPolygonFeature.ShapeCopy
            newPolygonFeatureCentroid = TryCast(newPolygonArea.Centroid, IPoint)
        End If
        Return newPolygonFeatureCentroid
    End Function
I left out the specific where clause for the query filter used, I figured that you would have that already, or already have the particular feature that you want the centroid of...
Hope this helps.
Kevin Orcutt
GIS Developer/Consultant
City of Cincinnati - Cincinnati Area GIS (CAGIS)
(513) 850-1335 (cell)
Kevin.Orcutt@cincinnati-oh.gov
www.cagis.org
