Hi All, I have tried to find posts about why this is happening but none have been able to help me. I have an automated mapping app which creates a legend on the fly. This all works fine until I try to use the code below to change the XOffset of the layer name text for layers which are symbolised with a UVR. The same code draws all items but the results in the actual legend seem to be random with different indents for different layers. Whats more, if I click the 'Draw' button in my app again it will recreate the legend differently although nothing has changed. Can anyone please help me either a. indent the layer name or b. indent the UVR patches beneath the layer name, I need to make it clear which patches below to layers with multiple symbologies. I am using VB.Net and ArcGIS 10 SP5.Thanks in advance, any help is much appreciated.If (TypeOf geofeaturelayer.Renderer Is IUniqueValueRenderer) Then
Dim pUVRend As IUniqueValueRenderer
pUVRend = geofeaturelayer.Renderer
For fldcount As Integer = pUVRend.FieldCount - 1 To 0 Step -1
For valcount As Integer = pUVRend.ValueCount - 1 To 0 Step -1
If UVRValueInMap(pUVRend.Field(fldcount), pUVRend.Value(valcount), pFeatureSelection) = False Then
pUVRend.RemoveValue(pUVRend.Value(valcount))
End If
'Setup font for layername and set the layer name visible in the legend
Dim newfont As IFontDisp = New StdFont
With newfont
.Bold = True
.Name = "Arial"
.Size = 10
End With
Dim textsymbol As ISimpleTextSymbol = New TextSymbol
With textsymbol
.Font = newfont
.XOffset = 10
End With
pLegendItem.LayerNameSymbol = textsymbol
pLegendItem.ShowLayerName = True
End If
