how convert .shp file to text file?
6052
07-29-2015 02:20 AM
Amalhaji
can anybody help me to write a C# or vb.net program which converts shape file (polygon) to text file using arcobjects
JaiSiva1
New Contributor III
Hi Amal,
  If your requirement is to see the bounds & attributes information in a readable way , i would suggest you to convert from SHP to geojson.
If that is the case, you dont really need arcobjects , a simple web application would do.
FreddieGibson
Occasional Contributor III
Have you tried using the geoprocessor to call the Table to Table Converstion tool?
Table to Table
http://desktop.arcgis.com/en/desktop/latest/tools/conversion-toolbox/table-to-table.htm
How to Run a Geoprocessing Tool (ArcObjects)
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000003rr000000
