How to display absolute file path of .mxd document in a message box
864
08-15-2010 12:33 AM
MuzammilAK
Dear All,
I have a command (developed using .NET SDK) in ArcMap, on clicking it should display absolute file path of that .mxd document in a message box.
please help.
thank you.
regards
Muzammil
vincentLahaye
New Contributor II
hi,
i don't know if it's what you are looking for, but IMapDocument.DocumentFileName give you the mxd path.
Vincent
ModyBuchbinder
MuzammilAK
Dear Vincent,
I have tried your suggestion in following ways, but neither of it works. When tried to cast its always null.
1. Here mapDoc is always null.
IMapDocument mapDoc = ((IMxDocument)m_application.Document).FocusMap as IMapDocument;
2. Here also, mapDoc is always null.
IMapDocument mapDoc = m_application.Document as IMapDocument;
Please suggest some sample.
Thank you.
Regards
Muzammil
AndrewMay
Try
ITemplates templates = application.Templates;
return templates.get_Item(templates.Count - 1);
The reason you are getting null values with the examples you've given is that you're trying to cast to IMapDocument but the objects implement the IDocument interface.
i.e. IDocument mapDoc = m_application.Document as IDocument;
should not be null (unless m_application is null or you've not loaded a document)
