IFeatureEdit.Split fails with network I/O error when processing large number of lines
558
01-11-2012 10:23 AM
MHawkins
I've developed VB.Net a tool to split all lines in a selected layer at the intersection of a point feature. Its use in a current project is for each of 17000 points, locate the line intersected by the point, split the line, populate various fields. The tool has started running very slowly, processing only one or two features per second and randomly throwing the following exception. Sometimes it will successfully edit 1500 features and sometimes 50 before this error is encountered.
[ATTACH=CONFIG]11092[/ATTACH]
I've tried using both IFeatureEdit.Split which creates two new lines and deletes the old one and IFeatureEdit2.SplitWithUpdate which shortens original line to split point and creates a new line for the other half of the original line. Both run equally slowly.
   Public Sub SplitAtPoint2(ByRef LineFeatLayer As IFeatureLayer, ByVal pPointFeature As IFeature)
        'On Error GoTo ErrorHandler
        Dim pPointFC As IFeatureClass
        Dim pSFilter As ISpatialFilter
        Dim pLineCursor As IFeatureCursor
        Dim pLineFeature As IFeature
        Dim pLineFC As IFeatureClass
        Dim pCurve As ICurve
        Dim pFeatureEdit As IFeatureEdit2
        'Dim pFeatureEdit As IFeatureEdit
        Dim pPoint As IPoint
        Dim SplitOccured As Boolean = False
        Dim pRelOp As IRelationalOperator
        Dim pEditorLayers As IEditLayers
        Dim pUid As New UID
        Dim pEnumLayer As IEnumLayer
        Dim pLayer As ILayer
        Dim pFLayer As IFeatureLayer
        Dim pPolygon As IPolygon
        Dim pTopoOp As ITopologicalOperator
        Dim UnitID As String = ""
        Dim UnitID2 As String = ""
        Dim UnitID3 As String = ""
        Dim UnitIDIndx As Integer
        Dim UnitIDIndx2 As Integer
        Dim UnitIDIndx3 As Integer
        UnitIDIndx3 = pPointFeature.Fields.FindFieldByAliasName("WWW_ID")
        If IsDBNull(pPointFeature.Value(UnitIDIndx3)) Then
            UnitID3 = Nothing
        Else
            UnitID3 = CType(pPointFeature.Value(UnitIDIndx3), String)
        End If
        Dim TempCurve As ICurve
        Dim NewLines As ISet
        Dim TempLine As IFeature
        pPointFC = pPointFeature.Class
        pPoint = pPointFeature.Shape
        'Create spatial filter to find intersecting features at this given point
        pSFilter = New SpatialFilter
        pTopoOp = pPoint
        pPolygon = pTopoOp.Buffer(dTolerance)
        pSFilter.Geometry = pPolygon
        pSFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
        If LineFeatLayer.FeatureClass.ShapeType = esriGeometryType.esriGeometryPolyline Then
            pSFilter.GeometryField = LineFeatLayer.FeatureClass.ShapeFieldName
            pLineFC = LineFeatLayer.FeatureClass
            pLineCursor = pLineFC.Search(pSFilter, False)
            pLineFeature = pLineCursor.NextFeature
            If Not pLineFeature Is Nothing Then
                UnitIDIndx = pLineFeature.Fields.FindFieldByAliasName("UNITID")
                UnitIDIndx2 = pLineFeature.Fields.FindFieldByAliasName("UNITID2")
            End If
            Do While Not pLineFeature Is Nothing
                If IsDBNull(pLineFeature.Value(UnitIDIndx)) Then
                    UnitID = Nothing
                Else
                    UnitID = pLineFeature.Value(UnitIDIndx)
                End If
                If IsDBNull(pLineFeature.Value(UnitIDIndx2)) Then
                    UnitID2 = Nothing
                Else
                    UnitID2 = pLineFeature.Value(UnitIDIndx2)
                End If
                pFeatureEdit = pLineFeature
                pRelOp = pPolygon
                pCurve = pLineFeature.Shape
                If Not (pRelOp.Contains(pCurve.FromPoint)) And Not (pRelOp.Contains(pCurve.ToPoint)) Then
                    NewLines = pFeatureEdit.Split(pPoint)
                    'NewLines = pFeatureEdit.SplitWithUpdate(pPoint)
                    Dim i As Integer = 0
                    NewLines.Reset()
                    TempLine = NewLines.Next
                    While Not TempLine Is Nothing
                        TempCurve = TempLine.Shape
                        If TempCurve.ToPoint.Compare(pCurve.ToPoint) = 0 Then
                            TempLine.Value(UnitIDIndx2) = UnitID2
                            TempLine.Value(UnitIDIndx) = UnitID3
                        End If
                        If TempCurve.FromPoint.Compare(pCurve.FromPoint) = 0 Then
                            TempLine.Value(UnitIDIndx2) = UnitID3
                        End If
                        If Not TempLine Is Nothing Then
                            TempLine.Store()
                        End If
                    End While
                    NewLines = Nothing
                    lCount += 1
                    SplitOccured = True
                    Exit Do
                End If
            Loop
            If SplitOccured = False Then
                PointNoSplit += 1
            End If
            'pLineCursor.Flush()
            pLineCursor = Nothing
            pLineFeature = Nothing
            UnitID = Nothing
            UnitID2 = Nothing
            UnitID3 = Nothing
            TempCurve = Nothing
            NewLines = Nothing
            TempLine = Nothing
        End If
        pSFilter = Nothing
        pPointFC = Nothing
        pCurve = Nothing
        pFeatureEdit = Nothing
        pPoint = Nothing
        SplitOccured = Nothing
        pRelOp = Nothing
        pEditorLayers = Nothing
        pUid = Nothing
        pEnumLayer = Nothing
        pLayer = Nothing
        pFLayer = Nothing
        pPolygon = Nothing
        pTopoOp = Nothing
        Exit Sub
        'AbortEdit3:
        '        pEditor.AbortOperation()
        '        Debug.Print("Error spliting at point " & pPointFeature.OID)
        'ErrorHandler:
        '        MsgBox("SplitAtPoint FAIL: " & Err.Description)
    End Sub
In ArcGIS 9.3 this tool ran fine and would complete processing of the 1700 features in an hour or so. I'm in the process of upgrading the tool to work with ArcGIS 10 but can't seem to resolve this issue.
I'm running ArcGIS 10.0 Service pack 2 on a Windows XP machine. I've tried it on a machine with Win 7, ArcGIS 10.0 SP2 with same result. As I did for the 9.3 implementation of this tool, I've set the JET engine max # of records to calculate in the ArcMap Advanced Settings Utility to one million to prevent hitting the max number of tables limit.
Any input or suggestions would be greatly appreciated.
Mark
