I am creating a disconnected checkout replica using CreateReplica on my PARENT Geodataserver, then Importing into a CHILD geodatabase. My customers will be replicating from my PARENT Geodatabase to locations worldwide and I was wondering if there is a more efficient way of doing this. I have went through every option available for CreateReplica and cannot find a more efficient way then this below. It seems to take forever for the import to happen. It takes me over a minute and I am located in the same space as the server itself. I have had one user timeout at ten minutes, so I thought I would take another look.
//Create the Replica on the Server
IGDSData gsdata = ParentGeoDataServer.CreateReplica("", ReplicaName.ToUpper(), gpReplicaDesc, replicaOptions, replicaExportOptions, esriGDSTransportType.esriGDSTransportTypeEmbedded);
//Import the Replica
ChildGeoDataServer.ImportData(gsdata, esriGDSImportFormat.esriGDSImportFormatFileGDB);
Does anyone know how to perform this action in the Help for IGeoDataServer.CreateReplica Method. I have searched the ENTIRE internet trying to do this documentation here.
"For check-out replicas, you can also choose to replicate directly to a file geodatabase or personal geodatabase. Here the output is the replica geodatabase and therefore no import is required."
Then I could just skip the import if somehow I could cast the IGDSData object to my ChildGeoDataServer (File GDB) and not have to do that long import process.
