Migrate VBA directly to Add-Ins or VBA to VB.NET then to Add-Ins
469
01-19-2012 12:42 PM
RobertHanover
Dear ArcObjects Developers,
I have to migrate several 9.3 applications from VBA to 10.0 Add-Ins.  Is it easier to migrate to VB.NET first and then to Add-Ins?  Or, should I go straight from VBA to Add-Ins?
Thank You,
Robert Hanover
Ohio Dept. of Natural Resources
RichardFairhurst
MVP Honored Contributor
Thank You,
Robert Hanover
I am going straight to Add-Ins.  I am checking out whether an Add-In button can be used with stamdard Windows forms.  According to ESRI support I am supposed to be able to do that.  In any case, Add-Ins have some limitations, but they simplify deployment, so they are attractive if you have to distribute your tools.
JeffreyHamblin
New Contributor III
Hello Robert,
The easist option, imo, is VBA to Add-In. You can code the Add-In in VB.NET, C#, or JAVA.
A year ago I put together a tutorial on converting a simple VBA 9.3 ArcMap utility that included a button that launches a form and performs a simple move features operation. It converts the VBA to a C# Add-In, but the process for VB.NET is very similar and with less changes needed to go from VBA to VB.NET.
VBA to Add-In Conversion Tutorial
