I am in process of converting an old VB6(ArcGIS 9.3) Add-on to .NET Add-Ins for ArcMap 10.6
the Add-on allows the user to Split or Merge road segments and adjusts their addresses accordingly.
The Old one contain:
1- 2 Forms: Setup Form and the split Form.
2- a Class Module that communicate between the forms and Error Handler Module.
Attaching the class Module.
I have no idea on how to start this project, I have no clear information of how to get the right solution
since I have snapping in the tool and the way of the error handling.
My Question is Which approach should I follow, Using Add-ins (is there any snapping limitation) or use com.
for either way you advice:
1- what the steps I have to follow, and how can I use the Error Handler.
2- what solution Template in VS 2017 should I use
Looking for any Help. and clsSplitroad code migration will be great help.
Thank you
