Hello everyone,
I have develop an Add-in with different functions.
The Add-in file is stored in a share folder.
Add-In manager has been set to that folder. (see Capture.PNG)
Reference by: https://desktop.arcgis.com/en/arcmap/latest/analyze/python-addins/sharing-and-installing-add-ins.htm...
"Sharing add-ins on a network"
Problem 1:
Normally, the Add-in functions can use after the ArcMap was open.
Sometimes, ArcMap cannot run the Add-in successfully.
Problem 2:
The client also need to use multi ArcMap with this Add-In for their work in the same computer.
However, second ArcMap always cannot run the Add-in.
My question is how to make sure the Add-In can be use in ArcMap every time even multi ArcMap in the same computer or different computers?
Thank you.
Environment:
ArcMap 10.7.1
ArcObject SDK in C# .Net
Development tool: Visual Studio 2017
OS: Windows 10 with domain user login
Share drive and computer are in the same network
