problem zooming when window minimized
2860
10-08-2014 06:03 AM
JeffRogholt
New Contributor II
We're using Developer Kit 10.1 in a vb.net win forms app.  The app listens for messages in the message queue.  The message contains x/y.  When a message is received, the map goes to the location.  When the form is visible/open the zooming works but when form is minimized it does not zoom to the correct location.
These are the steps to reproduce the issue:
Minimize the form
Send a message containing x/y
Restore/open/maximize the form and the map is in the wrong location
Here is a snippet of code:
Private Shared Sub ZoomMap(ByVal map As AxMapControl, _
                            ByVal pt As IPoint)
    Dim mapExtent As IEnvelope
    mapExtent = map.Extent
    mapExtent.CenterAt(pt)
    map.Extent = mapExtent
End Sub
Is this a bug?  Is there another way (not using CenterAt) to get the expected behavior?  Any suggestions or help is appreciated.
Jeff
JeffRogholt
New Contributor II
anyone have any insight on this?
AhmedEl-Sisi
Occasional Contributor III
I tested your function with 10.1 and windows forms app with scenario zooming to a specific location using timer.
I press the Zoom button and minimize the window, then maximize it again and it zooms to the right location.
I found no problems with that.
Also you can check this zoom function:
ArcObjects 10 .NET SDK Help
