question about using ESRI.ArcGIS.Display.RubberPoint and TrackNew();
770
06-06-2012 09:42 AM
AdamSlayton
I have a custom dialog box which has a button that when pressed runs the following function:
private void getPoint(ESRI.ArcGIS.Carto.IActiveView myView)
            listenerTrial lt = new listenerTrial();
            ESRI.ArcGIS.Geometry.IPoint myPt = lt.GetPointFromClicks(myView);
            double x = myPt.X;
            double y = myPt.Y;
            string echo = x.ToString();
            this.textBox1.Text = echo;
            echo = y.ToString();
            this.textBox2.Text = echo;
The GetPointFromClicks method from the listenerTrial Class has the following code:
public ESRI.ArcGIS.Geometry.IPoint GetPointFromClicks(ESRI.ArcGIS.Carto.IActiveView activeView)
            ESRI.ArcGIS.Display.IScreenDisplay screenDisplay = activeView.ScreenDisplay;
            ESRI.ArcGIS.Display.RubberPoint ptBand = new ESRI.ArcGIS.Display.RubberPoint();
            ESRI.ArcGIS.Geometry.IGeometry geometry = ptBand.TrackNew(screenDisplay, null);
            ESRI.ArcGIS.Geometry.IPoint mPt = (ESRI.ArcGIS.Geometry.IPoint)geometry;
            return mPt;
The function returns the geometry of a point, unfortuneately, it returns the the coordinates of my mouse cursor when the button on the original dialog box was clicked.
Any thoughts on how to get the function to wait for a click on the map (myView object)
KenBuja
MVP Esteemed Contributor
Take a look at this post for an example for an add-in
AdamSlayton
Thanks, Ken. The sample you pointed out helped solve my issue.
KenBuja
Glad to help. Don't forget to mark the question as answered.
