Showing topology erros on map.
523
03-20-2012 07:04 AM
RobertoOliveira
Hello all,
I'm having a little problem with my program.
My map is on a geodatabase, and I'm creating a topology programmatically, with all the rules, and validations.
Then, if the topology have any error, show a message to the user, and I like to show the topology error on map too.
But my problem is, how I add the topology to the TOC?
Maybe is simple, maybe not, but I don't know how!
Any help?
My code:
// connect to the ArcSDE
IWorkspace workSpace = ArcSDEWorkspace(connectionsProperty);
// create a workspace
IFeatureWorkspace featureWorkspace = workSpace as IFeatureWorkspace;
// open the feature dataset
IFeatureDataset featureDataset = featureWorkspace.OpenFeatureDataset("TopologyTest");
// get the feature classes
IFeatureClass ShapeA = featureWorkspace.OpenFeatureClass("ShapeA");
IFeatureClass ShapeB = featureWorkspace.OpenFeatureClass("ShapeB");
// lock
ISchemaLock schemaLock = featureDataset as ISchemaLock;
try
    schemaLock.ChangeSchemaLock(esriSchemaLock.esriExclusiveSchemaLock);
    // create the topology
    ITopologyContainer2 topologyContainer = featureDataset as ITopologyContainer2;
    ITopology topology = topologyContainer.CreateTopology("tpTest", topologyContainer.DefaultClusterTolerance, -1, "");
    // add the feature class to the topology
    topology.AddClass(ShapeA, 5, 1, 1, false);
    topology.AddClass(ShapeB, 5, 1, 1, false);
    // add the rules
    AddRuleToTopology(topology, esriTopologyRuleType.esriTRTAreaCoveredByArea, "My Rule", ShapeB, 1, ShapeA, 1);
    // validate topology
    IGeoDataset geoDataset = topology as IGeoDataset;
    IEnvelope envelope = geoDataset.Extent;
    ValidateTopology(topology, envelope);
    // check if the topology has some error
    if (topology.State == esriTopologyState.esriTSAnalyzedWithErrors)
        System.Windows.Forms.MessageBox.Show("Error!");
        // TODO: add the topology to the current document!! HOW!?
    else
        System.Windows.Forms.MessageBox.Show("No error!");
catch (Exception ex)
finally
    // unlock
    schemaLock.ChangeSchemaLock(esriSchemaLock.esriSharedSchemaLock);
RobertoOliveira
Forget, it's more simple than I thought.
Only think that I want is add the topology in the current document, and this is how I made:
// current document
IMap map = ArcMap.Document.ActiveView.FocusMap;
// create a topologyLayer
ITopologyLayer topologyLayer = new TopologyLayerClass();
topologyLayer.Topology = topology;
// create a layer from topology
ILayer tpErrors = topologyLayer as ILayer;
tpErrors.Name = "Errors";
// finally, add the layer
map.AddLayer(tpErrors);
