Hi!
So if ever anybody has the same problem, I finally managed to get the Code run.
Private Sub CalculateField()
' Access the Feature in Layer Flow whre fields should be summed up
Dim pMxDoc As IMxDocument
Dim pFeatLayer As IFeatureLayer
Dim pFeatureClass As IFeatureClass
Dim pFeatureCursor As IFeatureCursor
Dim pField As IField
Dim pFeature As IFeature
Set pMxDoc = ThisDocument
Set pFeatLayer = pMxDoc.FocusMap.Layer(0)
Set pFeatureClass = pFeatLayer.FeatureClass
Set pFeatureCursor = pFeatureClass.Search(Nothing, False)
Set pFeature = pFeatureCursor.NextFeature
' Access the Feature in Layer AREA that shall be calculated
Dim pFeatLayer2 As IFeatureLayer
Dim pFeatureClass2 As IFeatureClass
Dim pFeatureCursor2 As IFeatureCursor
Dim pField2 As IField
Dim pFeature2 As IFeature
Set pFeatLayer2 = pMxDoc.FocusMap.Layer(1)
Set pFeatureClass2 = pFeatLayer2.FeatureClass
Set pFeatureCursor2 = pFeatureClass2.Search(Nothing, False)
Set pFeature2 = pFeatureCursor2.NextFeature
'Dim Variables
Dim pAmount As Double
Dim n As Double
Dim m As String
Dim nTo As String
Dim Storage As Double
' Prepare a feature cursor for update
Dim pUpdateFeaturesU As IFeatureCursor
Set pFeatureClassU = pFeatLayer2.FeatureClass
Set pUpdateFeaturesU = pFeatureClass2.Update(Nothing, False)
Dim indexClass As Integer
Dim pFeatureU As IFeature
indexClass = pUpdateFeaturesU.FindField("Storage")
Set pFeatureU = pUpdateFeaturesU.NextFeature
'Do Until Loop to step through each AREA Layer feature
Do Until pFeature2 Is Nothing
m = pFeature2.Value(pFeature2.Fields.FindField("AREA_CODE"))
n = 0
'Do until Loop to step through each Flow Layer Feature and sum it up if the Field "To_" ="AREA_CODE"
Do Until pFeature Is Nothing
pAmount = pFeature.Value(pFeature.Fields.FindField("Amount"))
nTo = pFeature.Value(pFeature.Fields.FindField("To_"))
If nTo = m Then
n = pAmount + n
Else: n = n
End If
Loop
pFeatureU.Value(indexClass) = n
pUpdateFeaturesU.UpdateFeature pFeatureU
Loop
End Sub
Hope that helps someone out there
CU
