I have been using ArcPad for a number of years. I utilize geodatabases and the check-in/check-out tool that ArcPad has within ArcMap. I have been fine and dandy, until I added two fields I want to edit in the field. These two fields are text fields, with 350 characters. I use ArcPad 10.2
So my issue:
I have added two new fields into my shapefile (within the geodatabase), they are editable within ArcMap. However, when I check-out the data, both of these fields will not allow me to edit them on my mobile GPS unit (a Trimble Juno). I am able to write text into them, but then when I press "ok", those edits are not saved.
I have re-exported the data, and checked-out multiple times, thinking it was just an ArcMap "moment", but that was unsuccessful. In addition, I have also made sure that within the properties of the geodatabase that the field is in fact editable.
If anyone has solutions or a method I could trouble shoot this, it would be appreciated.
Thank you.
