Hi Gareth,
Good idea on uploading the data. It's not an issue of overlapping features though. When you zoom in close you can see the colors just fine. But we're trying to be able to look at the entire county and get a 'big picture' view of what areas are done, what areas need work. Over time the map should change from red to green because as the field crews are collecting data on each sample, they change the value of the field that is being symbolized on.
In the attached data, I've removed most of the fields and I'm symbolizing on the TierCode field, as an example. The point is to be able to view the colors of the line, even when zoomed out to 1:300,000.
This particular symbology shows the colors in ArcMap when zoomed out but not in ArcPad.
I appreciate you responding and looking into this.
Faith
