Hi all,
I need some help on a particularly strange case.
The laptop configuration is : XP SP3, ArcPad 7.1.1 and ArcGIS 9.3
I have a really simple database (few features classes and few attributes for each classes).
I check out data from the Database, collect data in the field with an ArcPad 7.1.1 and check-in data back in the DB. Or try to check -in.
While trying to check-in the data, I got this behaviour :
1. All data are not checked-in, the checkin process stops (not crash). and ask for checking in again
2. Or, I can't check-in at all.
I am using either GPS Analyst (using GPSCorrect in the field) or the check-in process of the ArcPad data manager toolbar when features are digitized.
This is happening with both checking in processes.
So, as a summary, with ArcPad 7.1.1 and ArcGIS 9.3 this is not working.
I tried to recreate the database (copy features classes, import features from shp into totally equivalent feature classes, copy/paste database....) but the problem is still the same.
What is really strange in this is that this is working with the configuration (I can check all data - no error messages)
1. Laptop : ArcGIS 10/ArcPad 10
2. Mobile device : ArcPad 7.1.1
Working with GPS Analyst or ArcPad Data Manager Tool
I know that this configuration can work because the axf structure is closed from a release of arcpad to another. So I am Ok with this.
....but this is not work with this configuration (same behaviour as the first configuration)
1. Laptop : ArcGIS 9.3/ArcPad 10
...this is not working.
And this issue is only happening for this specific database I am using. I recreate a new database (less feature classes, less attributes) and with the first configuration (ArcPad 7.1.1,ArcGIS 9.3, ArcPad 7.1.1) it is working properly.
Is there an exception with the first configuration. Is this issue from ArcPad Data Manager 7.1.1 side ? ArcGIS 9.3 ?
I am not sure to be really clear with all this, but I really don't know what to do with this particular case. Maybe I missed something in the DB structure. I can provide it if needed.
Thanks for any help
Best regards
Julien
