Error with .apm that contain layers from enterprise geodatabases
2286
06-25-2014 06:32 AM
HaniDraidi
Occasional Contributor II
When I open a .apm file that contains layers that point to an enterprise geodatabases, the error in the attached image below appears, but when the data source is a file geodatabase this error does not appear. Whats the problem here?
???SQL Server 2014 is installed, and when I installed ArcPad I installed SQL Server 2005 Compact Edition.
Regards,
Hani
[ATTACH=CONFIG]34868[/ATTACH]
Tags (3)
JamalNUMAN
Legendary Contributor
�?�SQL Server 2014 is installed, and when I installed ArcPad I installed SQL Server 2005 Compact Edition.
Regards,
Hani
Hi Hani,
I got the same error! See below
[ATTACH=CONFIG]34923[/ATTACH], [ATTACH=CONFIG]34924[/ATTACH]
Jamal Numan
