This thread is a year old, but I have a similar question. I have nearly 400 SSF files in my GNSS Sessions folder in a personal geodatabase. I'm approaching the size limit of 2GB and I think these files are what is causing that. Previously we used an empty back up of the database and copied the data over which reduced the size, but it's starting to rise again. In the GPS Analyst Help it says that files out of the GNSS folder can not be deleted. Is the only solution to uncheck the GNSS enable box and re-check it? I had no part in setting this database up, I'm just the one who uses it everyday so changing things makes me nervous that I might mess something up.
