Since ArcMap 10.3.1 the generated JPG2000 won't work anymore in ArcPad 10.2. I'm using the ArcPad Data Manager 10.0 Extention to convert a MXD-Project for ArcPad.
The problem is that ArcGIS 10.3.1 generates a corrupted *.jpg2.aux.xml file. Did anybody make a similar experience?
I'm using EPSG 9902, I hope that's not the problem. The generated XML file looks like that:
<PAMDataset>
<Metadata>
<MDI key="Corder">PCRL</MDI>
</Metadata>
<Metadata domain="xml:gml.root-instance">
<MDI key="<gml">FeatureCollection xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd">
<gml:boundedBy>
<gml:Null>withheld</gml:Null>
</gml:boundedBy>
<gml:featureMember>
<gml:FeatureCollection>
<gml:featureMember>
<gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001">
<gml:rectifiedGridDomain>
<gml:RectifiedGrid dimension="2">
</gml:RectifiedGridCoverage>
</gml:featureMember>
</gml:FeatureCollection>
</MDI>
</Metadata>
<Metadata domain="xml:CRSDictionary.gml">
<MDI key="<gml">Dictionary gml:id="CRSU1" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<gml:dictionaryEntry>
<gml:ProjectedCRS gml:id="ogrcrs13">
<gml:srsName>DHDN_3_Degree_Gauss_Zone_3</gml:srsName>
<gml:baseCRS>
</gml:ProjectedCRS>
</gml:dictionaryEntry>
</gml:Dictionary>
</MDI>
</Metadata>
<Metadata domain="Esri">
<MDI key="PyramidResamplingType">NEAREST</MDI>
</Metadata>
<PAMRasterBand band="1">
<Histograms>
</Histograms>
<Metadata domain="IMAGE_STRUCTURE">
<MDI key="COMPRESSION">JP2000</MDI>
</Metadata>
<Metadata>
<MDI key="SourceBandIndex">0</MDI>
<MDI key="STATISTICS_COVARIANCES">2195.994657066516,1948.976467658431,1811.804962385833</MDI>
<MDI key="STATISTICS_EXCLUDEDVALUES"></MDI>
<MDI key="STATISTICS_MAXIMUM">255</MDI>
<MDI key="STATISTICS_MEAN">89,487069317156</MDI>
<MDI key="STATISTICS_MINIMUM">0</MDI>
<MDI key="STATISTICS_SKIPFACTORX">1</MDI>
<MDI key="STATISTICS_SKIPFACTORY">1</MDI>
<MDI key="STATISTICS_STDDEV">46,861441047694</MDI>
</Metadata>
</PAMRasterBand>
<PAMRasterBand band="2">
</PAMRasterBand>
</PAMDataset>
One thing is that the less-than sign ( <
< ) and the greater-than sign ( >
> ) are not correct shown. The other thing is that the NoDataVaue-tags are missing:
<NoDataValue>2.56000000000000E+002</NoDataValue>
Also the whole header is corrupted.
However I was able to repair the XML file manual:
<PAMDataset>
<Metadata domain="xml:gml.root-instance" format="xml">
<gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengeospatial.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd">
<gml:boundedBy>
</gml:boundedBy>
<gml:featureMember>
<gml:featureMember>
</Metadata>
<Metadata domain="xml:CRSDictionary.gml" format="xml">
<gml:Dictionary gml:id="CRSU1" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<gml:ProjectedCRS gml:id="ogrcrs25">
<gml:baseCRS>
</gml:ProjectedCRS>
</gml:Dictionary>
</Metadata>
<Metadata domain="ESRI">
</Metadata>
<Histograms>
</Histograms>
</Metadata>
<Metadata>
</Metadata>
</PAMRasterBand>
</PAMRasterBand>
</PAMDataset>
How can I fix that problem permanently?
Updated
Can anybody confirm that this is a bug from ArcMap 10.3?
