ArcReader 5 compatibility with older .PMF files
1923
12-30-2016 01:21 PM
BruceLang
Our primary ArcGIS Desktop/ArcReader systems must stay at version 10.3.1.  However, I'm thinking of updating ArcReader only PC's from 10.3.1 to version 5.0 because they meet hardware & software requirements.
So then, does ArcReader 5.0 read PMF files created by ArcPublisher 10.3.1?  Thank you.
Additional Info:
  • OS: Windows 7 Pro 64bit
  • Server: SQL Server 2012 with ArcGIS Enterprise Geodatabase
JayantaPoddar
It should be compatible. Why don't you install an ArcReader 10.5 in a machine (with no other ArcGIS Products) and test it?
Esri Downloads - ArcReader
Think Location
BruceLang
Thanks jayanta.poddar, but "Should be compatible" is not the same as "yes, I know it's compatible" - plus, we don't have an extra PC for testing purposes.
JayantaPoddar
Why not upgrade one of the ArcReader software in ArcReader-only machine? I never had the issue with reading the older PMF files in newer version of ArcReader. It's just that I haven't tested 10.5.
Think Location
