I'm having trouble getting my head around using the ArcReader control in Visual Studio to customize an ArcReader application. I'm just familiarizing myself with this customization of arcreader capability.
In a new form (design mode), I go to the tool box, and add the Esri AxArcReaderControl to the Form.
When I enter debugger, I invariably get an InvalidOperatorException was unhandled error. I'm doing something simple wrong....
Are there clear/succinct tutorials for customizing ArcReader applications (Step by Step).
Another related issue I'm having is in regards to the sample code that I load into Visual Studio. I load up the sample code (for example DocumentProperties). I compile it and it loads fine. But as soon as I begin to customize the code at all, or customize the layout (i.e. resize the ArReaderControl box) the project becomes unrunnable). The error message becomes:
Error 1 Could not load file or assembly 'file:///C:/Program Files (x86)/ArcGIS/DeveloperKit10.0/DotNet/ESRI.ArcGIS.ADF.Local.dll' or one of its dependencies. An attempt was made to load a program with an incorrect format. Line 221, position 5. C:\Program Files (x86)\ArcGIS\DeveloperKit10.0\Samples\ArcObjectsNet\ARControlMapTools\VBNET\MapTools.resX 221 5 MapTools2010
I can't even succesfully open a .pmf through the reader control.
Someone pointing me in the write direction would be forever appreciated!!
